Hi, it's Moderneezer.
There's something that has gotten into my mind lately which relates to electric wiring. It's about switches on appliances with unpolarized plugs. Inform yourselves about the difference between polarized and unpolarized plugs, and also about the different plug shapes in the different countries on earth.
If an appliance has a polarized plug, then its switch would only need to cut the hot connection (also called active in Australia), but with an unpolarized plug, the appliance should have a switch that cuts both the hot and the neutral connections when turning off the machine. It said said, however, that appliances with unpolarized plugs used in the countries of mainland Europe generally have single-pole switches.
It is said in some websites (they're in French) that an appliance, with a single-pole switch, would generate some form of radiation if the hot connector is connected to neutral and vice-versa. American electricians are worried about other kinds of problems if a machine is plugged with reversed wiring.
The pictures are the wiring diagrams of canister vacuum cleaners. The canister represented in the first picture has a single-pole switch and is assumed to have an American plug with the neutral blade being wider than the hot blade. In the second picture, the appliance has a double-pole switch and is assumed to have an unpolarized European plug with cylindrical prongs. The machine in the third picture is assumed to have the same kind of plug as in the second diagram but with a single-pole switch. Notice the exclamation marks to warn us about some dangers?
So, in conclusion, an appliance with an unpolarized plug should have a double-pole switch but most of the ones in mainland Europe don't. What do you think of my opinion?
