That's its name lol
Success Hand Vacuum Cleaner
Hutchison Mfg. Co.
Wilkinsburg, PA
This was the other half of the auction lot with that AirWay. $10 for the lot. It was full of dirt and the filter was caked solid. It's also torn, I'll need to make a new one, not a big deal. Interestingly the nozzle had a clog. So I fixed a hundred year old clog today lol. But like, apparently somebody'd been using it until it didn't work anymore.
The leather bellows is torn. Not a big surprise given the cow died probably over a century ago. I've gotta find a leather couch to skin.
The wheels are interesting. One of them is stuck solid, nothing a little oxy-acetelyne won't fix. They are steel wheels, and pretty intricately machined for something that could've been plastic or wood. The screw for each wheel is the bearing surface for the wheel, and they also have a grease reservoir, covered by a set screw. Turn the screw in to squeeze the grease and lube the wheel. Also one wheel screw is a left hand thread and the other is right hand thread, presumably to prevent them from unscrewing during use. I'm not a machinist, but I'm thinking each wheel screw needs at least six different machining operations, and that's assuming they started with hex stock. Really kind of ridiculous how over-engineered the wheels are. Hell, it doesn't even really *need* wheels!
The U-shaped handle was bright nickel once upon a time. Replating that will be a big project I probably won't undertake for many years. I think at most, I'll make a new filter, bellows, fix the wheels, and polish the nozzle. Got a lot of projects ongoing, though.
Oh, also, on the top of the bellows there is a bypass valve. So you can just let air in the bellows? No idea why. This whole thing is over-engineered, it's fascinating.
Hutchison Mfg. Co.
Wilkinsburg, PA
