Some Hoover Vault Finds...
Those are just beautiful Tom! That bag is wrinkled cause its old! Ha, just like most old bags get........wrinkled!
BTW, you mention that a couple these were near the last 3000 of the production run. Do you have any knowledge of what Hoover's production output would have been per week/month? Just wondered how many they might have produced per day/shift, etc. of the Convertibles....
Jimmy...
Too funny...old bags!LOL! Production was around 2,000 or so machines I was told. However, I am not sure if that was per shift or total output for a 24 hour period. They did not run the line 24/7 for days at a time. So if a machine was produced for a year it was an on again off again situation the way that I understood it at least at this time. It was sort of easy to switch models on a line since there was so much component sharing between the machines.
--Tom
Another item I picked up was a 334 serial number 1001...the only problem is with the cord. It happens to be very crispy although the machine runs strong and quiet. I would never use this one as it does not have a paper bag in it.
rear of the bag as it goes into the machine...this is where the damage usually happened as the machine aged. This one is brand new and has never had dirt go through it.
I also picked up the first version of the Hoover Guardsman. It has rear conversion, different lettering on the bag, C tube, black cord, step on switch without a cover (a'la model 31). This baby is super clean and has never been used so it just gleams!
This unit is one that I have been looking forward to adding to my collection. It is a model 652 and it is mint. I have had fun checking out the differences between this model and the model 65. Unfortunately, I cannot say if it runs or how well it runs as I have no way of testing it. It is just a beautiful machine.
Here is a close up of the plug which is the same as the model 1334 that I posted photos of on this thread already. Note the bag is printed on the "US" side of the bag and not the "UK" side of the bag. The bag is the same material that we used but this particular one is so soft. I have never seen anything like it. The cord is very thick and obviously matches the cleaner to a "T".
Here are the bottom details. The main difference is the foot switch which is very similar to our model 31 switch sans location. The switch actuator is very simple in function but really over engineered and would be durable. I had to take the switch out to lubricate it as it was not "clicking" like it should. This is a one speed. There is no high speed switch like the US version. All in all, it is very, very well built!
Here is the serial number details. Maybe our UK guys could tell me more about this machine? This one is a beauty!
...the handle grip...the handle is aluminum not steel like the US 65. Also, it seems to me that the handle is shorter! When I compare the 65 to the 652, the 65 is taller! Can anyone tell me why?
Tom~
Feel free to send that 652 to me, and I'll be glad to test it for you...plugged into my voltage converter. :-)
I can take pictures, video... It'd be just like being there!
~Fred
Interesting! It is indeed US voltage, Tom! Maybe you can test it out sooner than you might have thought! :-) Oh...just be careful!
~~K~~
Why would Hoover UK make a 652 for US voltage and not give it a US plug? Same goes for the Junior 1334. Odd to say the least.
--Tom
UK Voltage
Hey Tom
240V didnt become the standard universal voltage till approx 1967- before that it varied between approx 80 and 260v. Because of this Hoovers were made to suit and its not unheard of to come across examples that have been converted to 240v- normally the rating plate is filed and restamped to show this.
I guess it would have been easy therefore to fit that with a 115V motor- is the 1334 the same???
Seamus
Thanks Seamus...both the 1334 and the 652 share the same 100-115 voltage. I guess I will have to find a way to plug in both machines...any suggestions? I could easily remove the plugs and put on a US plug. I would rather have some kind of "converter" to add to the end of the 652 and then just plug it into my US socket. This way I could keep both machines original. Thanks again for the info, I really appreciate it.
--Tom
