Sirena refurb worth it? What about Quantum X?
Wow
What happened to the regular Quantum Vac? (the one that looked like Sirena and Rainbow?) I only see the Quantum X now. Did they completely discontinue it already?
I don’t see them on Amazon any more, and the direct website is no longer active. I would have gotten one if it were still an option, especially because they did offer a mini power nozzle. But I am glad now I didn’t get the chance if they’re not going to be around to help if something goes wrong.
Started Spring Cleaning
I bought both electric and non-electric hoses from RainVac, and I put the electric one to use today.
First I pulled the couch out to vacuum behind and under it. I used the eucalyptus scent and definitely had the wrong water level and amount of scent. It foamed up real bad and I had to turn the vacuum off. So from that point onwards I used water only.
Then I cleaned my carpeted stairs. The hose reaches all but the top step which was a bit of a bummer. Though I’m sure if I could have had a wand attached, it wouldn’t have been an issue. I vacuum the stairs regularly with a V11, but of course the Rainbow pulled a lot of dirt out of them.
I cleaned the bin out and put fresh water in it again and did the upstairs area. My water was black again. But I did clean 2 areas that I hadn’t been able to with the Rainbow yet.
I can’t wait to reach a point that the water isn’t so dirty. The longer hose helped for sure, as I didn’t have to tote the motor unit around as much.
I can’t help but wonder if I’d vacuumed my upstairs and the stairs themselves with a new Kirby when I first moved in, if I would’ve filled a bag. I know I would have filled a Guardian Platinum bag.
lux_luthor
your post caused me to recall when I first got my first Rainbow. I lived in a 720sq/ft apartment and it took 4 vacuuming sessions to finally get semi clear water!! I was stunned!!!! I had been using my new Oreck XL and who knows what was used before me there.
This is the first Rainbow I’ve owned. My family passed one around in the 90s but my dad only got ahold of it once and I couldn’t remember much about it.
It’s been exciting seeing all the stuff it cleans up. And it’s even more exciting to know it’s out of my home! And of course it’s thought provoking wondering what other high end vacs would find. 😆
I spent 3
hours this morning doing my master bedroom. Stripped sheets, vacuumed the mattress. Dusted the entire room with the dusting brush. I use the floor/wall brush to get under the bed and dresser/baseboards/blinds and then ran the PN. I've never had essential oils foam though. That's weird.
Glad you got the 2 hoses. I think at some point I'm going to order the berry scent from rainvac. The rexair scents smell so good but the one I can't stand is Gardenia...Apple blossom is so so (not horrible but not great) The spice smells amazing to me, as does the Lemon, Pine and Orange. Berry must be a new scent I don't ever remember it so I want to try it. It's crazy how long those little bottles of scent last. When I bought my Rainbow in 2006, I'm still using the 4 pack of scents that came with it and the big huge bottle of green deodorizer is almost gone...I can get away with using a little bit of the green deodorizer without foaming, like half a capful. I might get more.....I still like using essential oil better though.
I’m using a Rexair scent. From what I’ve seen on RainVac it is not an essential oil. That’s probably one reason I have the issue with foaming.
I plan to use Slightly less water and far less scent stuff next time. I’ll get it figured out eventually.
I’ve spent this week working on college assignments. I’m trying to get ahead as much as possible while I’m off from work this week. But I plan to give my home a top to bottom Rainbowing before the weekend is over.
I saw a video on YouTube where someone measured out the “best” amount of water without using scents. What do y’all think?
That's a cool video (LOL).
Here's the thing. Just fill it above the dome....where the dome in the center is totally covered and then add just a bit more water. I vacuumed for an hour on one fill yesterday and when I was done, the water/dirt were still above the dome.
I do think anything oil based will make the water surface tension change somewhat, which is a good thing.
I think every rainbow scent is water-soluble.. essential oil is not.(at least from what I understand). I think I remember someone on here saying if the planets are aligned just perfectly, that there's a 0.00001% chance that the rainbow cound catch fire when using anything oil based. A super low chance of that happening. I've never had issues with essential oil. After having my rainbow all these years and super clean inside, I can pretty much confidently say that a few drops of essential oil in a rainbow is fine.
As for the small bottles of Rexair scents, a little of that goes a long way - just like essential oil. I basically just squirt one quick squirt in (that's it) hardly any. If I had to guess I'd say maybe you put in way too much of the scent? I have absolutely no foam when using those scents. But I've never put in very much each time. You should try the spice. It doesn't sound like Spice would be a pleasant clean smell but for whatever reason it's amazing. Like I said earlier, the Gardenia is NASTY to me.
I forgot to mention
You had said essential oils are pretty much bad for cats. I have to wonder about any scents period, whether it's essential oil or rainbow scents or even candles. Based on what I've read, since they have a heightened sense of smell, it would irritate them. But wouldn't that be the same with any scents? I guess I'm asking myself if Lemon essential oil isn't safe for cats, why would Lemon Rexair scents be safe? See what I'm saying? LOL At any rate, my cat has never seemed irritated or bothered by it at all. She's over 15 years old now and very precious to me. I'm so nervous of her age thinking it's all downhill from here with her at that age, but so far so good. I'll be devastated if something happens to her. She adores me and I adore her.
I’ll measure things out to your specifications when I use it next.
I keep meaning to look up more about the essential oils thing. I can’t remember exactly what about them does something now.
I would be upset if something happened to either of mine.
I’ve got to remember to vacuum off their cat tree.
By the way, if you don’t have a “Chom Chom”, I’d recommend it. That thing has been excellent for removing cat hair from my sofa, chairs, and cat beds.
My personal experience with Sirenna has been this: I bought the refurb. machine for $500 and thought that it was new when I received it. It cleaned great. The attachments and fragrances were up to quality standards like Rainbow however the second adjustable wand for the floor brush is just too short. It is not long enough to enjoy using like the electrified one. Also, I had an electrical smell coming from the motor everytime I used it. I called Sirenna customer service and they said that it most likely was a new motor smell from the carbon brushes and that it would go away. But after about 2 months of weekly use it didn't go away and I ended up taking the whole thing apart and cleaning the armature myself with a stone used for such a purpose but it didn't help. I never figured out why it was smelling like that but I ultimately sold it.
Motor smell
I bought my Sirena new, and I have to agree it had the worst "new motor" smell of anything I have ever purchased. I found using the fragrances helped mask the odor, but it took a good year before I didn't wonder if the thing was burning up inside.
Two years later, I have had a couple problems. The power nozzle had difficulties with stopping. It was found the fuse holder was broken. Sirena sent me a new one with instructions. It was about a 10 minute repair.
Second one was the very delicate, and brittle latches on the electrified hose. If you break one, which is easy to do, you have to replace the entire hose.
I don't see Sirena up to the quality of a Rainbow, but then again, it cost me a fraction of the price, it cleans well, and I have been satisfied with it. If it were my only vacuum. I am not sure there would be any love lost.
Hold up
To be fair...those clips at the end of Sirena are brittle but so are Rainbows. That's a weak point of the rainbow because I was carrying a hose over my shoulder and the hose was sort of swinging along as I walked and the end of the hose hit the wall in a perfect way (not terribly hard) that it broke that clip. I can see Sirena hoses doing the same thing.
The Sirena motor smell - YES YES YES - Same! I've never figured it out, but there's something different slightly when using Sirena with (rainbow frangrances or essential oil) as opposed to using a Rainbow. The smell is still fresh, but it's not the same. It's like fresh mixed with a plastic hot motor smell. This was especially true the first few times I've used it. You literally couldn't smell anything but that. After a few uses it seemed to taper down somewhat, but not completely.
I wish I could sell mine but I've never sold a vacuum. I couldn't imagine what a PITA it would be the pack it all up.
I don't HATE the vacuum it was just a stupid purchase for me and I don't need it. If I didn't have my Rainbow I'd be using it a lot probably. But I'm sure if I had been using it as much as my Rainbow something would have broken by now. I already had trouble with the PN that was fixed under warranty. The PN is not my favorite PN in the world. It's so quiet that you can barely hear it over the Sirena running. It feels like it has good airflow but it feels so light weight and doesn't feel like it's digging up a lot. I'd rate the PN as satisfactory.
Power Nozzle
I am not in love with the Sirena Power nozzle. I don't like the adjustments that aren't marked. I wish it had a headlight. It appears to clean ok, but doesn't adjust down enough to clean the low pile indoor/outdoor type carpet.
Not bashing the machine, I use it quite frequently, and like it's performance, jut trying to be honest on it's con column.
I don't have a newer Rainbow, Mine is a D2 from 1976. The Rainbow I have has metal clips on the hose. I wanted a new Rainbow but my checkbook told me no. The Sirena is a good substitute on a budget.
Ya I'm not bashing it either. I agree with everything you said. The clips that can break. I was just pointing out that can happen in Rainbows too (at least the older ones)
It's an OK machine....It's just a few things I dislike about it that I've mentioned before.... but overall if I didn't have a Rainbow, I'd be fine with this machine. But having both, I can say that Rainbow is definitely better designed and built by far.
I still can't get over how many Rainbows I see online or on Ebay that look like they've been to HELL and back.
Sounds like I dodged a bullet by getting a refurbished Rainbow.
I measured the water to just above the dome, and only added 3 drops of scent. I didn’t squeeze the bottle at all, just let gravity pull them out. Happy to say no foaming. Lol. It still provided a noticeable scent.
Glad to have the 14ft non electric hose. I dusted top to bottom today and it made that less of a hassle. I kept the suction ring open and still had some strong airflow and suction at the end of the hose.
