Shark NV680UKT Replacement Motor/Base
davec
Manchester
Hi all,
Just a quick question which I was hoping someone could help me with... I am going to ring Shark tomorrow if I get chance in work to confirm if nobody here is able to assist.
The motor has failed on my NV680UKT. The bearing has seized causing the motor to stutter. I have found what appears to be a similar replacement part on the Shark website- an NV681UKT motor base.
Are these two parts compatible?
Thanks in advance.
Dave
https://sharkclean.co.uk/product/body-motor-base-for-nv681ukt-zidXHDNV681UKT
Has the motor failed, or the bearing? If it's the bearing just oil the bearing.
If the motor is bad as in melted/shorted out, open the vacuum up and look at the model/part # of the motor, you might be able to find the motor itself rather than buying a whole housing.
Well they might be ball bearings, in which case replace them. Though the motor base unit assembly is not really unreasonably priced. Not sure about the compatibility.
