jkbff
Well.. If you guys recall I had purchased a Sentria II for my mother last year for her birthday... Well, she has done nothing but complain about it since I got it for her...
Let me start this by saying She loves Kirby's and won't have anything but a Kirby...
I tried my hardest to talk her out of it but she wouldn't listen... So I purchased it. She has a sculptured carpet... The vacuum ratchets when she vacuums... What I mean by that is if you watch the fork from the transmission to the pivot as it goes forwards and back, as it hit a divot in the carpet, the transmission is pushing forward, jolts because of the divot, the pivot pushes the fork to neutral, but the vacuum is still propelling forward and so the fork slams into forward again, repeating the process multiple times per second... Making the transmission ratchet...
One would think this wouldn't be that big of a deal.. Change vacuuming speeds or angles or something... But the jolt of the handle being slammed/ratcheted combined with the fact that my mother is getting older and her skin isn't like what it used to be, she is getting bruised when she uses her vacuum...
She had a G3 that she got rid of when I got this for her, the G3 didn't ratchet because the transmission wasn't as sensitive, it had more of a gap from the forward distance to the neutral position to the reverse... It didn't have the center slide plate that had a self centering spring. (I am very tempted to put a g3 slide plate in the Sentria II!) Also, the seal on the nozzle was worn to the metal so it didn't gasp for air when it hit the divots of the carpet...
I've tried monkeying with the forward position and the reverse set screws, have gotten it to where it doesn't spin the gears when its in neutral and doesn't ratchet *as* much in drive, but I don't think this will last long or things will function properly set this way...
I don't want to be stuck with a vacuum that I DO NOT want (aside from the fact I have a new transmission coming in case I have to sell this machine but I already have 3 machines on hand). Do you guys have any suggestions on what I can do to make this machine more comfortable for her to vacuum with?
Here is a pic of the carpet... It is evil..
From Requested Vac Pics
