Sebo vacuum cleaners extreme heat
blakaeg
NW London, UK
All,
Been using a Sebo Felix machine recently and noticed how hot it gets. I know it's normal behaviour of the machine to get like that but considering its only 1300 watts, they feel like pushing around a giant Heater in the house.
I noticed the K1 range get very hot too. Can understand as contains a 2100 Watt motor in there.
Never noticed this amount of heat with any other machine apart from a Dyson DC02 that used to get so hot in use. That was purchased in 1997 and as far as I'm aware it still works today but isn't being used as a main machine now.
I read on the Sebo German website about the heat levels, so it must have been noted by others, I can imagine more so with the Felix domestic and Dart commercial machines due to the way the air exists the whole body.
Used an X1 machine which is around 14 years old and its my most favourite Sebo machine, like it more than an X1.1 or X4. It's quieter and smoother in operation and I love the matt plastic finish.
My Miele S8 and S6 both used to get hot when used in the highest speed, but I know what you mean about the Felix. I think that is part of its design downside due to the exhaust cover. I don't mind it though because my Felix rarely puts out a lot of heat because I seldom use the highest speed. Infact, the Felix is better than the Dart as the Dart used to give a roasting each time due to its fixed speed - great for cold homes or commercially cleaning lol.
The other vacuum that I used to have which blew a lot of hot air, and not helped by its thinner plastics was my old Bosch BSGL5PRO model. The hottest one I have ever experienced are the types with the exhausts on the rear end of a cylinder vacuum - Electrolux Powerplus springs to mind here. Not much use if you have painted stairs!
Modern vacs have their motors in little plastic cocoons or wrapped in insulating foam to reduce noise. Doing this makes it harder for them to cool. Old vacs used to blow hot air out of every seam, now it is carefully contained and routed through a HEPA exhaust filter, concentrating the heat in one spot. Old vacs had lower rpm motors and lot more copper wire in their fields. Today, copper is expensive, the minimum wire is used in fields and while an old Lamb two stage fan motor might spin at 22-24K rpm , many vacs today use single stage fans spinning 34K or more to get the same suction as the old motors using less materials and fewer assembly steps. But that higher rpm means more heat. Then you put that motor in the little cocoon or wrap it in foam, and there you go. You have a toaster.
I'll stick to my Toaster-Master for now....found it in a thrift store a week or two ago for $3!
D.T, there was one vacuum that had ALUMINUM for it's motor winding, The Dirt-Devil Featherlite! it was a horror story! Air blowing out of all seams isn't that good of an idea, think about carbon dust! shooting air out of a jet-hole in the back is tried and true, and even better when you throw a filter on there!
This whole thing about carbon dust from the brushes is way over rated. Most of the vacs I have are two to three decades old and have more than half their carbon brushes remaining on the original motors. In three dedades just how much carbon dust has been generated? On the older vacs most of what goes out through the many places motor exhaust escapes is dust the old fashioned paper dust bags and open cell foam secondary filter (if your old vacuum even had that much filtration!) didn't stop.
I just took apart an late 1990's Kenmore Progressive. It has no secondary filter (I think it disintegrated and went through the motor) and the pleats in the HEPA exhaust filter were pooched out like a Japanese fan. Inside the motor was packed, and I do mean packed with lint and dust, to the point that the armature and even the commutator were not visible. It looked like a floor brush motor. The vac had so much use that there are grooves worn in the bottom plastic from the cord rubbing as it was rewound. There is even a hole worn through in one spot. Ok, this thing has had lots of hard use.
But when I finally blew all the dust out of the motor and the brushes (even the brush housings were packed with dust, I had to push each brush in and blow compressed air through them to force it all out) I found a perfect looking commutator and pretty much as-new brushes. For all my criticisms of these Chinese motors it looks from this example that they wear like iron, and with that little brush wear how much of what came out the exhaust of that thing was carbon dust? Not much.
From a vacuum cleaner perhaps not much carbon is thrown into the air but from other domestic appliances in the home, carbon emissions are higher than they have ever been. More so in countries like UK and Europe where homes depend on central heating.
A lot of home owners are investing in HEPA air purifiers for good reason - the air quality in home in recent years has become dirtier.
Not helped by the probable usage of bagless vacuums spreading dust around...
Eh, are you going to try to tell me the air in a modern western home is dirtier today than it was in the day of oil fired lamps, wood stoves and horse manure piled high on city street awaiting disposal (not that I'm old enough to remember those days, lol)?
<p class="p1">Well, they use oil lamps in India so the air is always full of paraffin - but in a room only and India have ceiling fans so the smell clears away. Or air conditioners, which also produce carbon…</p>
<p class="p2"> </p>
<p class="p1">The smell of horse manure would probably not enter a home. </p>
<p class="p2"> </p>
<p class="p1">As for wood burning stoves - Id rather have that scent in the air. I rather like the smell of burning wood. And, only in the last couple of years due to the high cost of electricity in the UK, many people are changing their stoves to wood burning stoves so that it heats the whole home. A lot of the modern wood stoves have a vent that takes the smell away outside with burning wood.</p>
<p class="p2"> </p>
<p class="p1">So in far as air quality is concerned, a lot of modern appliances still put out a lot of carbon outwith whatever change from old traditional ways you might add in your modern home.</p>
How much carbon do you think is in that smoke you smell? Just asking. How about the smoke from oil lamps?
I saw some images of the lungs of Eskimos who lived traditional lives burning blubber for light and to cook with. These were from bodies preerved in the snow centuries old. Their lungs looked like those of three pack a day smokers. Indoor air quality in less developed economies and in our own societies a century ago was not good at all. Carbon comes in many forms and smoke from fires is a major source. Where I live wood burning fire places are not permitted in new construction and some places have restrictions on when you can use your existing wood burning fireplace. It's an air pollution problem for us.
I also laugh at smokers worrying about indoor air quality.
The comment about not smelling horse manure tells me you never lived anywhere near horses or livestock. If the wind blows the right (or is that the wrong) direction the smell can be over powering.
If you're going to go all anal on this, DT then believe me you won't have a fighting chance.
The amount of carbon in a home can be filtered through HEPA air purifiers. '
I actually live across from a farm and at one time in the year it is possible to smell the manure in the air. However it is not on a street and the farm is miles away, but close to my home as I can see it from the hill where my home is built on. The smell does not come into the home.
Tellingly, carbon and carbon dioxide is dangerously high in most western countries. The usage of gas and electricity contributes to those factors. Have a look at this table and you'll see what countries use the highest.
http://whatsyourimpact.org/greenhouse-gases/carbon-dioxide-sources
Has anybody noticed the cable gets hot with certain vacuums?
BTW My Dc04 doesn't get that hot, I vacuum for 25 mins- 45 mins and they just don't burn you.My Dc01 Detsijl does though for some reason... The HEPA Filteris what you can't touch after an hour of use
Yep. Tight filtration can restrict airflow and make for a hot motor. Also, if the owner of the vac shop I use is to be believed (and I trust him explicitly) the high price of copper has led motor manufacturers to reduce the amount of copper in the field while raising their amperage and rpm to get higher performance, leading to some very hot running motors. Combine this with tight filtration and you see where this is going.
This is something I've noticed with my Sebo D2, so much so that the air from the exhaust is actually hot rather than merely warm. To be fair, I don't think it's a trait specific to this brand, as I've experienced the same with Miele and other makes too. It's just what happens when you have a motor that pulls over 2kW, coupled with sound insulation inside the motor compartment and several stages of fine filtration.
The fans themselves will also generate some heat; they spin at tens of thousands of RPM, and the airflow through them creates friction. This is why some cleaners such as Nilfisk and the Hoover Freedom cylinder had an ass-backwards configuration, where the air passed over the motor first, and THEN through the fans. Keeps the motor itself slightly cooler than if it were arranged the opposite way round, as is usually the case.
Compressing air most certainly heats it up. The reverse scheme you mention used by Nilfisk and Hoover would require some additional ducting to ensure air goes through the fan but makes sense in terms of cooling the motor. Were these through flow fans or another configuration? I wonder how turning the motor/fan around affects airflow and suction, or if it has any effect?
I got too used to my Dyson DC24 which has a 650 watt motor so doesn't generate much heat in use. Despite the fact I know machines do get hot in use but the Sebo Felix feels like one big heater being pushed around due to the heat coming out of the motor and the way the hot air exists the body via the fabric filter wrap around on the body. I'm the summer, if I hold the machine a certain way outside, I can see the heat coming from the machine. A little like the heat coming from the hot Tarmac surface when driving in very hot weather.
The Felix is a nice unusual machine.
I only really notice the heat from my SEBO Felix when on full power. I only use this setting for a deep clean on carpets once a week or so. I use it on half to three quarters of power on the slider switch which I found very adequate both for floors and tool use. I sometimes use full power on hard floors too. That way you don't notice the heat so much from the exhaust filter.
May be the lower wattage motors coming out will generate less heat in general!
madaboutsebo,
That's a good suggestion. I'll try on lower setting next time I get to use it. My friends carpets tend to be very grubby so the max setting really gets them scrubbed up clean with the excellent double Helix brush on the Felix machine. I also use it on number 1 on all floor types and leave the brush on.
I would not dare to leave the brush on when using the Dyson DC24 due to the rattle issues I encountered before, when I demonstrated the rattle to him, first thing he asked is, if I turn off the brush on hard floor. The latest head I have had since June and it hasn't rattled yet lol
I think it comes down to past experiences of other models - for example so many owners' reviews I have read regarding the Felix complain about the high heat. I know I moaned it about myself when I bought the Dart commercial upright version a year before I bought the Felix. But as soon as I used the Felix I realised that it isn't like some other brand's offering.
The Dart is bad because it does not have variable suction control, so you get the full force of 1300 watts each time. The Felix is better because you get the choice of low, medium to high power via the slider.
But, as with most SEBO vacs, the brands and the models teach you do to things slightly different to what has gone on before. Where the Felix is concerned, you don't need full power for maximum pick up - so many owners easily forget that the Felix has two motors on board and that the 175 watt ET1 floor head has 4 manual height adjustments that can additionally improve pick up - without unnecessarily amping up the suction to match.
Blakaeg, your welcome but if I remember I think it was sebo_fan that mentioned it or suggested it once and I've tried it and it works a treat. You don't always need full power for vacuuming flooring especially carpets I feel now. Plus you do not get so much heat from the motor when not on full power. Be interesting to see if the lower watt Felix will emit less heat on full power probably will do.
That surprises me you use number 1 on the ET-1 head for all floors. Do you not find it hard to push on carpets? Suppose you get greater pick up I hard floors with the brush roll switched on. I know what you mean about the Dyson brush roll!
I use the ET-1 on number 1 for hard floors with the brush bar off on 3/4 to full power but I prefer the Deluxe Parquet Floor tool to vacuum my hard floors which are mainly tiles. I feel I get a better pickup. My carpets are short pile I could use number 1 height setting but find it hard to push the vacuum. I mainly use number 3 on 1/2 to 3/4 power and for a deeper cleaning number 2 on the same power setting. I occasionally use full power as and when I want. I find the 2 height settings clean my carpets great grooming and lifting the pile. How thick are the carpet you use the Felix on?
Have you tried the new synthetic bags? I've found these have help to give better performance without the vacuum having to be on full power.
I do indeed find it harder to push on number 1 but I suppose I like knowing the brush is at the lowest it can be. When I first got it, the head used to shut off because the motor couldn't cope with the pile thickness, but over time it has stopped and now works fine on the carpets at number 1.
Can't say I like the synthetic bags because the dirt in the bag when I've used it has got stuck to
The sides and noticed a slight loss of suction and the bag indicator going across. My friend who owns the Felix now also noticed the same thing. We simply push the dirt down with a wooden spoon and the suction is excellent again and the bag indicator disappears again.
Perhaps I'll try the lower setting next time I stay at the flat to see how it is like at the lower setting. Her flat has cat hair everywhere but the Felix can cope no probs. it's a Sebo Felix Classic and has the Parquet Brush somewhere hidden away at another property.
The brushes haven't warned down have they with the brush head now not switching off? I know what you mean always wanting them deep clean.
Thats interesting, I must admit I prefer them. I do notice the pet hair sticks to the side more with the synthetic bags but it still generally fills from the bottom. I've noticed the bag indicator hardly moves for me with the new type bags. Saying that my bags are full of mainly pet hair as well as general household dust and dirt properly why the bag indicator doesn't move much. I noticed it moved more using the paper bags. I only notice a slight change in suction as the synthetic bags fill compared to the paper ones which was noticeable as the bag became fuller. Great tip for pushing the dust and dirt down. My bag is nearly ready for changing and the bag indicator is only on a quarter! Must change both filters as not been changed in 7 years!! Saying that I didn't use it much in the first few years of owning it, and I'm only on my second box of bags too.
Do try the lower setting and let us know how you get on. The Felix does cope very well with pet hair. Mines the Felix Classic.
Thanks for that info sebo_fan I didn't know that about the delicate brush roll digging deeper. I've heard the delicate brush roll can wear down quicker than the harder blue bristle one. Are the bristles longer then for it to dig deeper? Suppose it's due to the bristles being softer. Might have to invest in one then!
Thats good Knowing that info for when I get an X series I would feel happier using the delicate brush roll on hard floors.
Glad I could help as always.
The bristles are the same length, just softer and green in colour. TBH I dont notice a big difference between the two with the choice of roller brushes.
What I do notice however is that the X is slightly heavier to push with the delicate brush roller fitted. I've since returned to using the harder bristles in my X1 Auto due to the sensor and the delicate brush roller in the Felix since it has the manual height adjustment.
You sure did thanks. Slowly getting to know the SEBO brand and it's vacuum cleaners more and more which I find interesting thank you for your help and knowledge and sharing too.
Might give the delicate brush roll a try, will have to order one when I order my new filters for my Felix. Suppose the softer bristles are able to dig deeper into the carpet pile. The Delicate brush roll must make the X series head lower more then with the standard harder bristles hence heavier to push.
I know SEBO would never make one but it would be nice to have an ET-1 head with automatic height adjustment like the X series but offer the one with manual height as well. The auto ET-1 head would have to have a hard floor setting so if you turn the brush bar off it lowers to a height suitable for hard floors unless you left the brush bar on. I know a silly idea!!
