steamawayclean
So my first Hoover model 300 1939. In fact my second vintage Hoover, the 1st being my Hoover dust at that I posted last week. But this will be my first upright. When I took it out of the box as you can see from the picture the side where you bolted on was broken off. The bag was still connected in shipping so the ear broke off the bag and the vacuum cleaner. I use some of this dr. Bond super glue that's for aluminum and plastic and such and it seems to be really strong so that was a plus. I guess as much of a plus as you could ask for. Event opened up the bottom and replace the belt I had a belt here a Hoover 48. So I put that belt on and then the handle was a little loose even when I tighten it all the way so I took that pipe clamp cut the nut off of it and just slid metal part in around the handle that way I'd have more to tighten and it works perfect. I then brought the vacuum cleaner into the living room and turned it on. It seems like it works for a minute and then when I picked it up to see if the beater bar was bending I saw that metal knob from the bottom of the motor sitting on the floor. I don't know if the belt was too tight or if the bottom of the motor was weak at that spot but it looked fine. I don't know what I did wrong I wouldn't think about that was a little too tight would SNAP that off. I'm pretty depressed about it right now considering I spent $80 on shipping from California but only 30 on the vacuum. I did purchase a 700 motor yesterday just because I saw it. I'm wondering if that 700 motor will fit on the 300 and I can swap them out. I also have a 541 on the way as well. Any expert opinion would be great since I'm still learning and like I said this is really depressing. Actually I did get a Hoover convertible last week as well and the height adjustment pedal was broken off and she didn't send the bolts for the handle two connected to the machine. So I have had the worst luck. MATT
