Rug Doctor?
Used to have the RD Wide Track and it's true, they do put out a lot of water. Part of the reason they work so well, but you do have to be careful about overwetting. Don't pull the machine back *too* slowly while spraying (particularly on berber type carpet), and be sure to follow up with plenty of dry strokes afterwards to lift out as much excess moisture as possible.
Mine was a Quick Dry version, with a knob at the rear allowing you to select either regular/quick dry mode. The latter reduces the solution flow rate, and I found that to be plenty for most jobs. Only for really heavily soiled carpets would I use the regular setting.
A lot of pro carpet cleaners are a bit sniffy about the RD, partly because it's something you can hire from the supermarket, but mostly because it doesn't cost thousands to purchase. Still has no bearing whatsoever on its capabilities though, and for domestic use it's hard to beat. In the hands of someone who knows what they are doing, or at least follows the instructions to the letter, it does an excellent job.
my neighbor had a rd the thing i dont like about it is ur hands go numb and it makes your arms feel like playing a nintendo wii
My aunt rented a rug doctor and asked me clean her living room with it. I did, but the thing was SO LOUD and bulky. It left the carpet soaked, and when it finally dried, the carpet looked dirtier than it was before. I took my Hoover Steamvac up, and it did so much better.
