Rug Doctor Portable Spot Cleaner
danorob1
Central New Jersey
Hello Again -
We purchased one of the Rug Doctor Spot cleaners at Costco about a month ago -
Another Great Product from Rug Doctor - And at Costco it was a steel - The clipless coupon cost was only $99.99 which included a bonus kit of three 32oz bottles of cleaning solution, and some kind of urine eliminator spray…
This thing works great - great suction - spots dry in no time at all - easy set up and clean up - vibrating brush like on our blue full size Rug Doctor…
With Two Rag-doll Cats and the dog, this was a must have - beats dragging the big rub doctor upstairs from the Garage every time someone has an accident…
It also fits perfectly on the stairs...
Here are some images...
I have to tell you that it does a really great Job -
If you pull off the recovery tank, the suction at the port is amazing -
I may to to open it up just to see what type of motor is in this thing -
Rugs are completely dry after only a couple of hours - and the Vibrating brush is great as well - Like a tiny hand held version of the full size machine that we have -
The only thing I am slight worried about is how long the electrical connections running through the hose will last - The pump trigger on the handle, along with the Brush on/off switch are both actually electric -
When you press the soap trigger, you hear the pump kick in - Same thing when you turn on the electric brush -
I am sure it will be fine, and I am sure the cable could always be replaced -
Like I said, far better then the Hoover or Bissell Unites for the same money or less -
Dan
I just picked one up at costco this past week for $109, when I saw that price I couldn't not take it. Just turned it on, but haven't used it.
