Royal upright motors
murf
TN
Will the 4.5
5.4 6.0 7.0 amp motors fit in the same motor housing with brushes.Say a 882,995,5700,9100,9600,880,903
murf
Charlie,
If these are the non-drop-in motor assemblies, then yes they will fit all the models that you mention.
History of these motor groups:
3.0 amp (early, before 1976)
1-801001-000 = armature (before 1973)
1-602001-000 = armature (1973-1976)
1-801002-000 = field
2-013107-000 = motor plate and bearing (all models except 153, 602 and 777)
2-016307-000 = motor plate and bearing (models 153, 602 and 777)
2-080126-000 = rear bearing (all models except 153, 602 and 777)
1-003026-000 = rear bearing (models 153, 602 and 777)
1-163026-000 = motor plate bearing (models 153, 602 and 777)
2-080127-000 = front bearing (all models except 153, 602 and 777)
1-053004-000 = fan
1-285261-000 = armature
3.0 amp (late, 1976-1985)
1-608001-000 = armature
2-088007-500 = motor plate and bearing (all models except 153, 3-153, 602, 3-602 and 777)
2-016307-000 = motor plate and bearing (models 153, 3-153, 602, 3-602 and 777)
2-080126-000 = rear bearing (all except 153, 3-153, 602, 3-602 and 777)
1-003026-000 = rear bearing (models 153, 3-153, 602, 3-602 and 777)
1-163026-000 = motor plate bearing (models 153, 3-153, 602, 3-602 and 777)
1-608004-000 = fan
1-608261-000 = shaft
4.5 amp (1980-1989)
1-880001-000 = armature
1-880002-000 = field
1-608004-000 = fan
5.4 amp (early, 1985-1990)
1-618001-000 = armature
1-618002-000 = field
1-620004-000 = fan
1-618261-000 = shaft
5.4 amp (late, 1990-1995)
1-884001-000 = armature
1-608005-000 = fan
1-380261-000 = shaft
6 amp (early, 1984-1990)
1-620001-000 = armature
1-620004-000 = fan
6 amp (late, 1990-1995)
1-680001-000 = armature
1-608005-000 = fan
7 amp (1990-1995)
1-780001-000 = armature
1-780002-000 = field
1-608005-000 = fan
~Ben[this post was last edited: 9/7/2018-16:28]
