ornery
Good Day All,
Yep, first post of yet another vacuum nube. First, want to say thanks to the helpful contributors here. I recently acquired an M1030Z from work. It was well used, and in need of some TLC. Thanks to a few threads found here, I know quite a bit about it, and it's running in tip top shape.
Just acquired a Model 880 this afternoon from the grandson of the original owner. It's got a 3 amp motor. Serial Number: 77m C 14944. Things I like about it:
* In GREAT condition!
* Attractive Powder Blue
* Relatively Quiet
* The "Adjust Rite" diaphram
* Only $30.00 from Craigslist-Cleveland
Things I don't like:
* Hand Knob Height Adjust
* Bottom Fill Bag
* No Quick Release Cord Hook
It was missing a belt when I got it, so I swapped one from the 1030Z. Not sure if that's a proper fit, but it's working. I don't want to wear out bearings in the roller or motor if that would be too tight.
Also, it had a sticking spring in the handle release latch. I pulled it out, and reshaped what seemed to be bent up, but I'll be darned if I can figure out how it's supposed to function. On the 1030Z, the lever is pushed down with your foot to release the handle. It's an entirely different mechanism. This 880 will latch itself using gravity alone. The spring I pulled out seemed to be pushing in the same direction as gravity. To release it, you have to lift with your foot. That seems wrong. Is it?
Thanks In Advance,
John
* Relatively Quiet
* Bottom Fill Bag
Thanks In Advance,
John
