Royal 4650 pigtail
dartman
Portland OR
Well my Starks/Royal 4650 finally destroyed the pigtail that goes into the swivel head thing on the base of the power head.
I could probably jury rig something that would work but if anyone has a good one or knows where to get one I'd appreciate it. The old ones done right where the cord emerges from the male plug to go into the power head so can't just strip it back and solder or put some crimp connectors on it to make it work. I have a blue 413 power tank but it uses a different power head and connectors so don't really want to steal or cut anything off it to custom make something that would work.
I figured out with a bunch of effort how to get the cord off the rest of it and that's where it sets for now.
Thanks for any info or parts.
Hey
I may be shooting in the dark but cut plug from a heavier extension cord. Buy a generic pig tail plug solder pig tail to extension cord. I'd use heat shrink over any exposed wires. It should work just make sure extension cord is same gauge wire as cord your replacing.
Yeah, I think I could use some drop light cord and make something that would work. Not sure if I have any in stock anymore but I'm sure I could dig some up. I could use the stuff from the other one but that would disable it so not going to do it.
Haven't used the 413 since I found the 4650 which has a much better power head when it's working. Have to look through my junk and see what I can dig up.
Unfortunately when I found the other powered hose to fix this one it didn't have the pigtail I need as far as I can remember.
Thanks, but that's just two regular ac male power plugs so won't do me any good. Now if I can find a official Royal round 2 pronged male plug with the proper spacing I could just swap the plug and it would work like before.
pig tail
did you find what you where looking for?
i came across a couple of plugs with wide spacing for the royals
and a few kenmore powerhead new have the wide spacing as well
if you still need give a shout out and we will chat
Ron.............
No, haven't been looking real hard yet, thinking about seeing if the 413 powertank still works and wondering who else might have used that plug setup. If you have one or can point me where I can get one let me know so contact me. I was thinking about just redoing it with some round droplight style cord and eliminating the plug but would be nice to have it work like it's supposed to if I ever want to just remove the powerhead.
If only the cord is broken off and none of the rest of it is damaged, you should be able to just dissect the molded plug, get the contacts out, solder on a new cord, and remold it all into epoxy glue.
pig tail plug
i do have a couple.....one is royal the other is kenmore both are wide spacing between pins.......ill try and post a picture of them asap.
Ron
Thanks, I'll hold off on hacking in a different cord then and wait to see what you come up with. I usually use IrfanView and resize all my pics to 800x600 and they upload fine here directly from my computer. Hopefully we can work something out and I don't care what color the cord is as long as it works. The hose was from a 4600 on eBay anyways so all the colors are mismatched now but it made my 25 buck local buy work again and cost way more than the whole vacuum did but it worked great from about 3 years ago when I Frankensteined all the parts together.
More pictures
Those are all good suggestions and here some more pictures to help make it easier to see if any of those cords will work. The pics are hard to make out to see what shape they are but one of them would probably work if I just used the plug and not the little housing it snaps into then into the rest of the hose pipe.
pig tail plug
the two straight ones i have here should fit inside that bracket
they are both from "royal"
ok i am going to send you an email in a couple of min
Ron
Well, checked in today and no mail yet but it might have gotten thrown in my spam. I broke out the blue 4.3 power team and it works fine except the hose is full of holes so I vacuumed the main living areas with it. A much simpler power head and cord setup for it but it just doesn't groom the carpet near as well and I used to love that machine, at least it works.
