Riccar® model № 1500P.2 canister vacuum hose assembly
Flâneur
United States
Hello!
I am interested in acquiring a spare hose assembly for my Riccar® model № 1500P.2 canister vacuum. The hose assembly's part number is "D362-0410" per the manufacturer's parts booklet (though I have seen a few on-line parts resellers use the part number "3623210410", as well).
The manufacturer designed the hose assembly in such a way that the hose tends to kink near its connection to the handle subassembly. Years of said kinking resulted in work-hardening of the wires in the hose, leading ultimately to their breaking and only intermittent functioning of the vacuum cleaner's power nozzle. I cut open the hose and successfully repaired the wires, but I cannot manage to mend the hose itself. Needless to say, I will store any replacement hose assembly disconnected from the wand assembly, in future.
Happy Thanksgiving!
Stalk ebay. They turn up. One sold last month.
I was going to suggest the same thing. One will turn up given time.
@cheesewonton @centralsweeper63
Understood. I will make it a point to browse eBay® listings at least weekly, if not more often.
I saw that there was a hose assembly sold on eBay® ostensibly as recently as October 5th; however, because eBay® seems not to display the year with the listing or selling date (whichever it is), I was unsure if the listing was posted or the sale made in a previous year. Thank you for the clarification!
True story, this past weekend I found an upper bearing and brush holder for a Hoover Dial-A-Matic. They are made of Bakelite and are very brittle, so it is basically impossible to change a worn out upper bearing without breaking it. It is maybe the only reason I don't use my working D-A-M ( one for show and one for go ) very often. Persistence paid off.
How badly is it damaged? You can buy heat-shrink wrapping for electrical cables that comes in large sheets for repairing big wires and maybe you might be able to reseal the hose using that.
