Revelation and Compact info requested
kirbyvertibles
Independence, KS
Hi fellow vacuum friends,
I have a curious question about Revelation. When did Interstate discontinue the Revelation? Also did the Rev ever have a PN plug for the ABC or Eureka nozzles?
I know the Compact Standard (pinkish tan color) did have the plug as I have one that is stamped S PB ( standard power brush) in the bottom.
If I am correct I believe the "standard" was a vac shop model like the Revelation was correct? So then why wouldn't they also have the PB option?
reply
The first Compact Tristar vacuum to have power head plug was the Compact C6 whit the abc power nozzole folowed by the yellow C8 then the blue c8,c9 yellow c9 blue c80 ,c80-2 then the cxl c80-2 twin speed and silver cxl and so forth .
My C5 has the ABC outlet as well. It's very clear that Interstate made way more vacuums set up for the ABC (Always Beauty Clean) powerhead than they made powerheads; only a handful of the powerheads are know to exist. I'd love to know the story behind this mystery.
I've seen photos of Revelation C-4s equipped with the ABC port so they must have been made into the very early '60s. I believe that although the Compact was transitioned into the three-wheel C-5 at that time Interstate kept the old C-4 design with rear wheels and front skids for the Revelation since it was a cheaper model.
