alexhoovers94
Hello all, I figured, since summer was here, I would restore some of the plastics on my vacuums that had turned yellow due to aging. The process may be familiar to some of you, known as “retro brighting”.
All you really need for this is the hot direct UV raise of the sun, which for best results, you need to do this on a hot summers day, that is not overcast. You need 12% 40 volume cream peroxide, (used for hair colouring) a brush for pasting the peroxide onto the items you would like to work on and a clear plastic box: The box is to cover the peroxide pasted items to prevent the solution from drying out.
Before you start, you need to make sure the plastic you want to restore is clean and dry, then you paste the peroxide on with the brush so that all the yellowed plastic is EVENLY covered, the layer of peroxide pasted onto the plastic needs to be of Goldilox consistency, not too much, not too little.
Set your parts in the hot sun and put the clear box over them and leave alone for the chemical reaction to take place! Be sure to check the parts every 30 minuets and move them around, so they get even coverage of the UV raise.
Once you see the yellowing has gone, wash off the peroxide and bobs your uncle!
Check the plastic to see if you have an even finish, if there are areas that are still a bit yellow, repeat the process.
Remember, this is a skill, so practice on something that is not of value to you, before attempting to restore something that is!
Hope you enjoyed this post, thanks for reading,
Alex.
Alex.
