Restored Westinghouse Upright
repairman
Woodridge, IL
After going through the pile of vacuums that Jon Durfor didn't want, I snagged this Westinghouse Upright. Despite how bad it looked (Sorry. No before pictures), the machine was complete and the brushroll looked to have been rebristled.
I took the thing apart down to the last screw as the wiring fell apart in my hands. The dry rotted cord was replaced with one that was scavenged from an Oreck Magnesium that was thrown away at work. Thankfully, the original strain relief was in great shape and I was able to reuse it.
The wiring coming from the field was a challenge however. It was cloth covered wire that was as brittle as spaghetti. Since there was some good wire right before it went into the field, I was able to amputate the brittle wiring and solder on some fresh cord using heatshrink afterward.
One of the screws holding in the handle fork was also broken off. One cut with a Dremel gave me a slot to be able to remove the screw with a screwdriver. The unit received a buffing job and was all done. So I thought.
I went to power on the machine and the bag had literally burst in half since the stitching was so fragile. Ray came like an angel from heaven and graciously sewed the bag back together using his serger which completed the project.
Upon seeing the fabric tube attached to the coupler, I had the idea to take a bag connector from a Sanitaire F&G outer bag to use paper bags. Now I can use Hoover C bags which are just the right size.
WOW! That looks great!! Where was it to become in such bad condition when you found it? Also, how does it sound? I've never heard one. My only suggestion would be to put a strain relief here(below) so it fits more snugly.
You beat me to it! The original plastic bushing had cracked. I plan on replacing it with a grommet when I get a chance.
All of the steel parts had some kind of coating that turned to rust. Hours on the wire wheel took care of that. The cover above the strain relief was an example of this.
I'll post a video soon. I also greased both bearings and it is very quiet.
Westinghouse
I think you're probably right on the age. Early 40's at that, or maybe even 30's, but definitely a pre-war machine. Post-war models would look similar to my F1-46, which was made about 1946. Here's a picture.
repairman
what a great looking restoration, glad you rescued another piece of history. Any idea what the raised 8 represents on the blower beneath the bag? Model 8?
kirbyklekter
If you're referring to picture 4 in the upper right corner, that is the rivet used to hold the bag collar into place. Think of the three mounting lugs on a Kirby for securing the emptor. This has one.
Thanks again to everyone for the kind words. I have some cloth covered wire on its way for it as I'm not too crazy about the Oreck Magnesium's cord. Looks too generic.
Cloth covered cord
I don't have any vacuums that old for cloth covered cord to be appropriate, but I've rewired a few of vintage lamps with it. Visually and aesthetically, it really does make a big difference. I miss being able to to buy that stuff off the spool at places like Lowe's and Home Depot. The last couple of times I've needed some, I've had to buy it online.
