cb123
This thing had a lot of bloated body bag caps hissin' fit to bust, and two old, decrepit resistors in the left channel causing some thermal issues with its outputs -- like the kind if you ran it for about an hour you could use the output transistors as a cigarette lighter to fire up your Virginia Slims...like that kind of thermal issue. Which was kind of strange about the resistors, on account, when they were cool the olms were an acceptable 10.5, but when they started warming up a little they jumped to 15 olms which was off biasing the outputs and for solid state that's pretty critical. Well, I got that all done and replaced all the blown lights including the radio needle bulb, and now at even 50% this thing can raise your roof! That's still pretty strange though about the resistors, they normally just usually creep up in value not fluctuate.
