Eureka4040A
- Joined
- Mar 6, 2014
- Messages
- 2
I own a 1979 vintage Eureka ESP wide track vacuum, model 4040A.
The cord wore out where it comes out of the handle and I need help repairing it.
The only help I've been able to find is here by HooverCelebrity.
www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?13369
His post gives a good idea of this challenge.
"The only gripe I have about this cleaner would be servicing the cord and switch. It's nearly impossible to do. The handle grip has to come off, the wires all go up the handle... you have to carefully take the switch out.. and if you want to remove the cord, you may as well forget it. Once that cord-strain gets pushed into the handle, you may as well cut it off and drill it out if you want to remove it. I have no idea how those cords would have been serviced on a regular basis back when those cleaners were more prevalent. Thankfully my cleaner had a perfect cord, but I tried taking the cord out of a different "parts machine" 2091 I had laying around, which was in pretty rough shape... and I cursed and gnashed my teeth trying to get that cord out, but I finally got it."
I haven't been able to find a schematic for the 4040A. The closest I've come is the
2000 series, which handle looks the same as the 4040A.
http://www.usavacuum.com/category-s/197.htm
My questions are:
1. How to remove the rubber handle grip from the top of the metal handle.
I've tried heating it up with a hair dryer and it still won't budge.
2. The 3-position ESP / off Rocker Switch just slides into the handle. It is not
held in place by screws. Can I pull it out? And if I do can I repair the
cord from there, and will it still work when I push it back in?
3. It looks like the 30 foot long main cord plugs into the back of the Rocker Switch.
Does it plug in or is it soldered?
4. Do you have a step-by-step plan for replacing this cord?
Thank you
My questions are:
Thank you
