Rainbow electric hose issue
Deleted member 5972
Recently I got a used rainbow e2 electric hose from ebay and it's in good condition. I brought it so I can save it for a rainbow e2 blue. Only problem I found out is that the end of the hose, there's a torn spot. Is there a way to fix it up? Since this one has double insulated wires. Thank you.👍
You
Can twist off the end of the hose in a counterclowise pattern. You cut the hose shorter and symmetrical and reinstall the end of the hose
I was thinking. Can a good type of super glue that has a good air tight seal and adhesive will work instead of me trying to take it apart or cut a piece of the hose off?
Lesinutah, just saw your post. A couple of days ago I got some miracle wrap and some super glue to close up the tear and then use some silicone sealant for the outside and inside.
