fantomfan
I just bought a Rainbow E2 and had trouble getting the separator off. I finally got it off with the prying end of the hammer. I bought a new separator and put it on but now it's just doing the same thing the old separator was doing. But now I can't even get it off the way I was able to with the old one. It's almost like it's been fused onto there. Could over-tightening the screw on the separator do this? The separator itself appears to be fine and the motor is fine but now I can't even get the new separator off. I definitely don't want to damage any parts up in the fan housing which if why I've stopped trying to get it off. This happened after only the first use with the new separator. I wanted to clean it RIGHT after I was done like you are supposed to do with Rainbows. I'm going to take it in eventually anyway to be serviced but I want to see if I can fix this myself beforehand because the vacuum itself works fine. Any thoughts?
