Vacuum Coffee Maker
Hi, yes it looks all there, the seal will soften if you wash in warm water and lube it with some rubber seal like easy glide is one we have here or if you can't find that use a little washing up liquid. Fill bottom tank with water to fill line, firmly place top tank on top have inserted the filter put med. ground coffee in top pot AND PUT THE LID ON. Plug in let water boil up to top pot, unplug remove lid stir once replace lid and coffee will vacuum back into bottom pot. Not sure about this one but some have a keep warn setting. Sorry this is a bit rushed.
