Procyon carpet shampoo
vacuumdevil
Vacuum Hell
Hey vacuumland I was wondering how many of you have used Procyon carpet shampoo?
I've been using it for years I first saw it at summoner AT VDTA. Didn't pay much attention to it then. They have pretty strange marketing. Years later I ended up working at a store that sold it. So of course I brought some home to try and was really impressed. I've been using it for years now.
There's no soap residue left behind with Procyon
It's apparently non-toxic and Green certified.
It can be purchased in concentrate powder.
if you overmix procyon when it dries it dries into a powder that can be vacuumed up.
Also it appears to be one of the best carpet cleaners in terms of strength.
https://www.amazon.com/shop/perform...=exp_inf_sh_mb_list_own_performancereviews_cp
I have never heard about it and mostly all cleaning companies on youtube I see always say to use simple green or tide powder detergent (and then they accompany this with a carpet scrubber like an oreck), so not sure, maybe its a cost thing or they just never heard about it.
@huskyvacs really it's been around for a long time. There are several professional truckmount companies in the Denver area who use it.
There are some really odd "professional carpet cleaning" channels on YouTube.
Only seen a couplewhere alright.
90s video ad here 😁
Can it be used as a LOMAC shampoo?
When you mentioned that it dried into a powder, that made me wonder if it had any encapsulating properties to it. I’m always looking for something new to try in my CRB machine In the Whittaker brand solutions don’t always do it for me.
@luxlife You make the concentrate powder into the liquids. I say plural liquids because you can make the powder into the pretreat or into the carpet shampooer.
Hope the video helps.
@vexorgtr I have used other and zep products and have been more then satisfied with them. Particularly commercial cleaners.
My understanding that Zep is an alkaline based product which must be rinsed out properly. There are lots of good cleaners on CRI's list. This just so happens to be very cost-effective and non-toxic for what that's worth.
Ive used it a few times there are better options out there
I clean carpets and flooring for a living. When I was researching what chemistry was out there I came across Procyon. I try to use the safest most effective chemicals out there. First time I used it I wasn't wowed by it. It does clean the carpet but I've used better. The encapsulation side of the chemical doesn't preform as well as polymer based chemicals out there.
Also side not : CAUTION: Avoid using Procyon, or other salt-based detergents. Salt-based detergents are highly corrosive and they have been known to cause significant damage. Using salt-based detergents can void the warranty.
This is a major reason why I don't use it. My equipment would get damaged. I use an Austrian Made CRB (counter rotating brush) machine to scrub the chemical into the carpet prior to extraction. The warning is clear that I should not use Procyon with this machine.
But for consumer use it mostly plastic constructed machines it just fine and better than anything sold in big box retail stores.
Ok, poor choice of words..
What I meant to say is that owning a CRB requires alot of diligence in keeping the brushes clean, rinsed after each use and placed in alternating positions on the machine. The machine needs to be wiped down after each use to prevent buildup of detergent, encap, etc.
I understand that
I clean it out each work day and usually just switch out the brushes per house I go to. I just found side by side results I can get better performance from other cleaners that aren't corrosive.
