Please explain
vacowacko
brigham city
Can someone please help me wrap my head around this. So as we all know Kirby and other vacuum demos use the "last one wins" method to "fake test" that their vacuum is the best. Even if it is. However my question is if a Kirby or others are supposedly capable of picking up dirt even under the pad as some say. Then why does it still leave things behind? How long of vacuuming would you have to do to get "everything" up? and why is it an impossible if so ?
No vacuum cleaner is cleaning dirt from under the pad, that's just not the truth. Most never carpet tends to have a layer in the backing that doesn't let moisture through very easily, and not much dirt will be going through that either. If you have a carpet where the backing is more open, you'll get dirt on top of the pad, and a good vacuum can help remove that, though ideally if you're actually vacuuming regularly with something that actually cleans, the idea is the dirt won't be building up and sinking in so deeply. The dirt they are actually getting up is all in and on top of the backing. And those Kirby demo pads are designed to make even a small amount of dirt look like a vast amount.
Kirbys seem particularly reliant on sealing to the rug being vacuumed. If anything breaks that seal like something that overlaps a rug or any part of the nozzle overhangs the edge of a big area rug they just seem to stop cleaning. Kirbys excel on nice unobstructed wall to wall carpet. Not so good when you have close furnishing and an odd assortment of area rugs and hallway runners.
As for the explanation, no vacuum is 100% effective on every pass. Maybe 70-75% pickup on the most amazing machines there has ever been. Then, on the next pass, you pick up 75% of 25% of the original dirt. Basically you are left with 1/4 of the dirt that was there last time. If your vacuum picks up 75% of dirt it would be 25% left over, 6.25%, 1.5625%, 0.390625, 0.09765625. As you can see it is impossible to get to nothing, only very close to nothing. Now, does your vacuum pick up 75% of dirt. Extremely unlikely, probably more like 50-60%
I took lots of A3 sized carpet samples of Loop wool, uneven loop wool, low pile nylon and medium pile nylon so there is varying levels, the Kirby tends to do fine so long as it is on it's lowest setting.
No. I have at least one rug that if I set the Kirby too low the belt will squeal and you will soon smell burned rubber.
If the Kirby sales person ever comes around again I am going to make them go first then see what is left with one of my small but insanely powerful Japanese vacuums. The Panasonic even has a dirt sensor light so we can embarrass the Kirby person with a little light show, lol. Then I can show him what is in the bag.
This is because the Generation series Kirbys did away with the suction relief valve on the nozzle that the Classic series had. There's no way for the air to escape. When using the Kirby to vacuum area rugs, if the rug is lightweight, the Kirby WILL eat the rug. This is why for people that have area rugs, the Kirby Diamond Edition with its dual speed switch is so critical to own.
This is the best explanation I have heard so far. But because it hurts my head just for the sake of it let's say you had a Brand new carpet and kept it vacuumed everyday for hours changing out bags. Keeping the entire air way clean potentially changing out the brush keeping everything 100 percent efficiency. Is there a point where it would be close to nothing picked up or would it continue to leave behind or drop out dirt? I know it's not super practical in a demo situation but what if a person was super OCD about it possible?
Well, if you vacuum a spot about 10 times with a good machine like a Kirby, power nozzle Sebo or anything with good cfm/waterlift and a really good brushroll you can reach an effective 100% but not a scientific 100%. You need a brushroll, airflow and waterlift to clean. It is like the fire triangle, more of one means less of the others. Waterlift is the least important and the other two are very similar in how important it is.
It's true. Even earlier this year my basement flooded so we had to rip some carpet up. There was definitely dirt underneath the pads. Despite that, I still prefer having carpets over barefloors.
With hard floors dust and dog hair glide in clumps, sound echoes and cleaning is a pain. With hard floors you need to extremely thoroughly (hard for the average person) vacuum or sweep the floor before washing it.
So the cleaning experts will all say that if you are prone to allergies you should wet mop hard floors with three buckets. One with detergent, one for wringing the mop out and a third with clear water. Vacuuming hard floors, according to the experts, is a no-no. We vacuum then wet mop. But living in the desert with dogs, cats, a rambunctious 11 year old boy and the ever present caliche dust you take your allergy meds and deal with it.
Even refinishing hardwood floors can be a pain as well unlike carpet cleaning. And despite how professional someone like these guys are with refinishing, not everything would look like brand new again.
