Place to rebuild Electrolux Model E motor?
appledude
My local shop said my trusty Electrolux model E finally needs its motor rebuilt - I am getting info on good shops to do this, and about what it should cost to do this.
My local shop said he has problem getting some parts for a motor this old any more.
Basically you clean the commutator on the armature , replace the brushes and evaluate and/or replace the bearings on either end of the armature shaft. There are ways to test the coil windings on the armature itself, but seldom is there a problem there unless the motor was stalled and got hot without the benefit of thermal shut-off sensors. Sometimes the commutator grooves are worn and too shallow...they can be deepened again with a special pull tool or a knife blade of the appropriate size.
Kevin
