atrac
Greetings Gents!
I picked up an Oreck XL Commercial vacuum today on the cheap....and I see why. Although the unit itself is in good condition, the motor is bad. When I first turned it on I got white smoke and very little movement. I opened it up, took the motor out (wires still attached) and (ok here's where I turn layman) saw the cylinder that spins with copper contacts on it was dirty. I also could see the copper wire wrapped all around it was dirty as well. I sprayed (gasp?) contact cleaner on everything. Let it dry. Then I used a flat head to gently clean the black corrosion off of the copper contacts. Now when I plug it in, I heard a little spinning noise, then nothing. And the nothing continues.
Did I kill it? Was it already dead? A waste of time to try to rebuild a vacuum motor?
Advice appreciated! Thanks!
