With the wiring in the house approaching 50 years old, I sometimes wonder if it’s still safe.
From what I’ve seen, my house wiring is probably fine, it’s all copper, and it seems like they used wire gauges for 20 amps on even the 15 amp circuits.
The breaker box is original too, and it’s a Square D QO series, which I think is pretty good quality. Can still get new breakers for it too.
Most of the outlets we use most often have been replaced. I still need to get all of the remaining ones replaced but most of them are in the bedrooms and aren’t used frequently and only for low current draw devices. Almost all of the original outlets in the house used push in wiring connections only, no screw terminals! I don’t like those at all because they can work loose over the years and you wouldn’t know. The switches though had both push in and screw terminals and they used the screws, go figure.
But other than that, I think everything is in good shape. Sometimes I get paranoid that a connection somewhere is overheating and smoldering ready to burst into flames. But like I said, I haven’t seen any reason to believe it’s the case.
I really don’t even hear of many electrical fires around here. I wonder if any homes here have aluminum wiring or knob and tube still.
I collect older fans and lamps and I don’t plug any of them in unless I’m using them. Just as an added precaution, although sometimes I wonder if the new stuff is less safe!
