maxeley4103
This is a quick and simple method for old Dysons. As everyone knows the older Dysons (Especially the British made ones) fade and become exceptionally brittle. Even us careful collectors can end up with cracks and splits in the plastics. If these cracks spread to much you can end up with large pieces of plastic breaking off making for sharp and ugly edges.
So what do you need. You will need, Toothpics or Ends of matches (which ever is to hand) and some Epoxy Resin or Acrylic Cement (Something like Gorilla glue).
The next part couldn’t be simpler. Mix the glue preferably do this outside or in a well ventilated room as most Epoxy trains come in two parts that need to be mixed in the correct ratio (FOLLOW PACKET INSTRUCTIONS). Using the end of your chosen spreading device apply a small blob of the glue around the crack and then spread it as evenly as you can along the crack going about 3 millimetres either side of the crack to make sure it holds. Do this of both sides of the piece of plastic (if accessible) you will then need to dry for about 24 hours
I hope this helps anyone worrying about severe damage to their old Dysons. This may not be the prettiest fix but it is easy and effective.
