Numatic help
Changing the motor
If you've got as far as changing the brushes a new motor should be a case of lift the old one out and unplug, then plug the new motor in and sit it back in the casing.
Hopefully someone who knows for certain will be along shortly, I once took a Henry to bits and had a right old job getting it back together as I'd paid no attention to the stripdown. Put me off it a bit on them!
Hello
I didn't change the switch as to be honest i'm not sure it's that, so I thought if I can get a motor, I'll bung a new one in as then at least the little guy will have a new motor so hopefully that should rule that potential problem out.
Now just to figure out how to do it & where to get one... :-)
Cheers
Dave
