Okay so this is a bit rant.
I have seen these been tested on the airflow box and results aren't impressive at all. Now to remind you they that they cost up to 1600$.
So obviously you will get huge performance from these due to the two motor system?
Sadly that's not the case here.
Nozzle airflow with the bypass motor only running is 76 cfm and both motors running 81 cfm. So direct air motor only boosts 5 cfm when it is added to the vacuum.
So my biggest complaint is that did they even test it when it left from the drawing board? There is quite many single suction motor uprights what can do the same and even better than this fancy tandem air vacuum.
Tandem air system doesn't add agitation or anything else. Only thing what it adds is the production cost and complexity of the vacuum.
You are better off with cheaper Riccar/Simplicity. They offer the same airflow and agitation and they cost a lot less. Naturally suction is unaffected by the Tandem air design.
My intention was not to upset anyone. These are raw numbers and they don't lie.
Just choose normal single suction upright and you will have the same or even more performance. If you really want high airflow upright go for the traditional direct air vacuum.
