Terry
I believe the Scott and Fetzer dates between 1920 something-
till 1935, as Charlie pointed out ! IT also has 2 different nozzle
adjustments on it. The Front wheel setting is on the side left of the cleaner (from behind the cleaner) which is a round button
(we'll have to get a picture of this)on the axel of the front
wheels, that you pulled out and could adjust to High,med,Low.
Then the roller brush inside the head turned with the wheels.
Plus you could adjust the brush contact to the carpet on the
back of the head, just to the right of the left wheel. I'll
have look again, to tell you how much play or adjustment.
The fact that the machine had the sani-emtor, height adjust-
ment and the same Kirby on/off switch like the 500 series. Was
all much of a surprise to me. I had actually seen this machine
once before briefly and knew it was a Kirby/Scott/Fetzer machine. Had never seen one in real time before. OH Plus the fact that
the head came off to connect the hose in front of the Fan,with
NO Shaft on it ! Just flat mounted inside like the Stright suction 1920 Eurekas are that I had seen many times before.
ONe other detail, is that the female end of the cord that plugs into the machine, is a bakelite material. not sure of
the material on the male end of the cord. I'll have look when
I head down to the basement today, to do some laundry and play with my new toys !!
Norm
