My best vacuum is a green Compact canister vacuum that I purchased new.
I have replaced the power cord and otherwise kept the machine running well.
It became very noisy so I took it apart and checked everything out, looking for a bad bearing or some obvious problem but found none.
I reassembled the vacuum and it continues to run albeit very loudly.
Suspect it could be the motor or the rubber motor mount. The motor mount(70039) is not as pliable as it was when it was new so it may be transferring the motor noise to the aluminum case instead of damping it.
Any owners out there that have encountered this problem?
Like to hear from you. Thanks.
