I'd rather have a vacuum that'd shut the brusholl off while the handle is up. I've used vacuums before where I'd use the hose while the brushroll is still spinning, and I'd see dust spit out of the brushroll. Plus if not careful, you could either accidently tangle up the brusholl from lets say a fishing line while you're busy using the hose without noticing. I think that happened to me once before. Or you can cause a burn mark on the carpet if the brushroll stayed on the same spot for very long. Yes there are vacuums that you can turn the brushroll off manually but I'm betting most of the consumers wouldn't do that themselves. My Kenmore Whispertone upright made by Panasonic that I have, it has not only a switch to turn the brushroll off manually but also the brusholl turns off when you take the hose out just like a Sebo Felix. But the Sebo Felix also shuts the brushroll off in upright locked position which I like more than my Kenmore.
