New Style Rainbowjet sponge head
williamr1248
USA
I just ordered a replacement sponge mop insert from Ken and he also sent me the NEWEST style sponge head. Love it, love it, love it.
I can do my regular sweeping with the fuller brush and just replace that lower wand with the new mop head. It uses so little water, I can go over my hard surface floors in an instant and remove any trace of dust left. I am using so little floor cleaner that I don't have to empty the basin from regular cleaning. That mop head is so easy to clean around chair legs,table legs,under the counter and cabinet toe space where a regular full size machine would NEVER go. When finished I just store the solution in the tank. It lasts for weeks as you are using so little each time. Once this new type sponge gets wet it really holds the right amount of moisture and just enough to pick up the dust but not leave any water or residue on the floor surface. No need to even flip it over for the squeegee side. The floor is dry.
Of course if you were going to clean a real dirty floor you could us more moisture or even use the floor head with the scrub brush and squeegee.
When the sun comes in the window, not a trace of any dust left of the hard surface flooring.
Just love the fact that I can do this any time I have the vacuum out for regular use and no special separate machine needed and no clean up.
How may times have you seen a picture where the wood floor is clean but the vacuum left that micro layer of dust that shows in the sunlight.
They are the SAME SIZE but the picture makes the old style look larger.
