Using the Rainjet makes taking care of Laminate floors so easy. It is small, lightweight and gets under and around furniture and appliances so easy. With the full sponge you clean your baseboards as the do the floor. It uses an amazingly small amount of cleaner  liquid.
I do my dry vacuuming first and then just snap the lower wand with the Rainjet on and go. When finished , just dump your basin and you have sanitized your hose at the same time. If you are doing a large area, empty your water basin first and your Rainbow will glide across the floor with ease. The angle and design of the squeegee and sponge allow use at the users choose of angles.
