New Hoover Constellation Questions
elux89
I've been considering purchasing one of these for some time, but have a few questions that the Hoover experts might be able to answer:
1. Has anyone used a suction and Baird airflow meter to determine the inches of lift and CFM??
2. What make and model of motor do these have, and are they a single or two stage fan unit??
Vernon
I seem to recall...
That the new Connie only has a 1 stage...
I think the machine is made by the parent company of Panasonic... the same company who makes the motors that are in Dysons...
***goes and gets screwdriver***
Yeah, Fred!
Thanks for checking that out for us. Gosh, one fan and surprising quiet and un-whiney. :-)
As dictated by today's litigious thinking, there is a 1/4" air leak hole under the handle back mount that I plugged nicely with a rubber button which is why I get a reading of 95".
I love mine!!! I herd from another vac shop that they were made by LG??? The only thing I don't like is the strech hose. I just don't like strech hoses. I use it all the time in my Atreium (sp???) aka big plant room.
Power Nozzle
Has anyone successfully coupled a power nozzle (not a turbo nozzle) with the new constellation. I would love to put a windtunnel power nozzle on mine. I just don't have the electrical know-how for the wiring..
Fred:
Thanks for tearing things to pieces and posting the pics.
Dave:
That air leak hole under the handle back you're referring to, I to noticed that and called Hoover asking why--they didn't have an answer for the hole
Vernon
Based on the autopsies I've performed on a myriad of modern plastic uprights and canisters, all new vacuums now come with a remotely located relief valve or positive leak - a 1/4" or larger HOLE - somewhere. A hole always defeats maximum available suction at all times. It's to prevent total sealing of the bag chamber so the cheaper high revving motor doesn't burn out. Better vacuums use a spring loaded relief valve that maintains full bag chamber suction until a total blockage happens.
Dave
Dave,
Just another thought on that hole, since the connie needs air to float on, the hole might be one way to ensure there is always enough airflow to float on.
I hear you on the better quality vacs having a spring loaded valve, like the taski bora 12 or older linhdaus healthcare pro hepa. Some even have a thermal protector on the motor.
Good point, Vern.
Continued floating is certainly a side benefit, but if my Connie is that plugged up I expect I'd turn it off and change the bag...or remove the obstruction which could very well be a cat toy. :-)
I like the idea of grafting a Hoover power Nozzle onto this powerful new Connie, as really it should have had. Just need a double coil hose and a power wand to make the design-appropriate connections. my Connie hose is missing the end handle but I do have the collapsing wand & Turbo Nozzle, which I note dispenses with the usual Hoover latch buttons & reverse connections in favour of standard tapered friction tip.
To the Partz Bins, Dr Davy...
