kirbyloverdan
The Ultimate in Performance and Beautiful Design
The Lux Guardian Platinum is designed to be stylish and durable, with intuitive performance, so you can create a clean, healthy home. Despite a high-powered motor, operation is exceptionally quiet and two sealed HEPA filters ensure the tiniest contaminants are captured and clean air is released. Featuring sleek design and stainless steel appearance, the Lux Guardian Platinum is a sophisticated appliance. With intelligent features such as the Automatic Operation Mode that senses what type of cleaning you are performing, and the System Indicator to alert you when maintenance is needed, you'll find everything you'd expect from a high-performance floor care system.
•High-Powered Motor - Features an amazing 505 air watts and 116" of water lift.
•Remarkably Quiet Operation - The Lux Guardian Platinum features an aerodynamic air guide design and multi-layered sound insulation.
•Sleek Design - The stainless steel design is protected by a special anti-fingerprint finish.
•Performance Indication - A System Indicator alerts the condition of operation including suction level & automatic mode, prefilter notification, full filter bag and over-heated motor.
•Intelligent Suction - Suction control can be adjusted across 8 levels according to the task you are performing. Control manually or automatically. Use maximum power for vacuuming floors and deep cleaning, medium power for vacuuming upholstery or dusting and minimum power for delicate cleaning.
•Simple Maneuverability - The 3-wheel guidance system makes the canister easy to pull as you vacuum. A rubberized coating prevents scratches on wood floors and ensures quiet operation.
•Convenient - An Automatic cord winder easily stores the 28-foot cord.
•Versatility - Top-mounted power switch is operated with a simple foot tap. Switches located on the handle adjust suction and turn off the power nozzle brush roll when using on hard surface flooring.
•Ease of Use - The unique L-shape power nozzle provides 4-sided cleaning and self-adjusts its height between types of flooring.
•LED Headlight - The Lux Guardian Platinum features a LED headlight that makes it easier to see in dark areas.
•Effortless Assembly - The patented Push & Pull Connection System makes inserting and removing the electrical hose effortless. The hose rotates 360° on both ends and the handle features an ergonomic design for comfort.
•Unique Parking Positions - The canister features two power nozzle parking positions, one on the side of the canister for interruptions while cleaning and one on the bottom of the canister for storage.
•Automatic Protection - If an object becomes tangled in the power nozzle brush, the circuit breaker will automatically shut off the brush to prevent damage. A built in thermo coupler protects the motor by shutting it down if it overheats.
•No Worries - The Lux Guardian Platinum features a worry free ownership with a 15-year limited warranty
[this post was last edited: 1/9/2013-17:07]
