What is the wattage of you bronze G? mine is the SAME old 53
Wattage on my bronze G is the same as my turq G's, ie 535 watts
Both of the turq G's in this shot look about the same from an outside appearance. But one must have take on more water thus the motor area got more corrosion.
The rusted "insides" of a tank unit can be subtle, one just has a rusty smell. Cleaning them out and painting the insides was done on every vac here that got flooded.
The Model G Vac by the door had a better outside, but was the horrible rusted motor pic already shown. The "new looking" Model G motor with new 8mm bearing was full of dried mud and just soaked and cleaned in water.
At some point it is easier to scrap out a unit if common, thus the model G by the door was just stripped of its wheels and other parts and scrapped.
Most normal folks threw everything out that went under water. 4 of these 6 vacs work today. The XXX body is re useable, its motor is a basketcase, but I have a spare!
**** As far as the bronze G having a bigger motor; MY bronze model G #U59484H says 115V 535 Watts, thus I wonder since it is the same as my turq G's and older F's.
A more modern model 1521 has a larger motor and it is marked 9 amps.
Mt model 1205 is at the house, I need to look at its nameplate
