My latest AWESOME find!!!
dustin
Jackson, MI
Eureka Model 2385 Cordaway! I found it at a local thrift shop, marked $24, but everything in the store was 1/2 off, so I paid $12. On first inspection, it was a bit dirty and had no belt- No big deal. I got it home, and threw a belt on. It runs great, everything works, although it could probably use a set of new brush strips (VG1). I did discover that there is a hole broken in the bag connector, which was taped over- again, no big deal. (The actual bag is in excellent condition, only a small worn spot at the bottom) Will glue a piece of plastic on from the inside. All original, metal fan, cord winder works perfect, power touch handle works, has a 2 speed, 3.5 amp motor that runs great. I can't believe the condition this thing is in, especally for its age (I'm guessing early to mid 70's?), only a few real scratches, mostly just scuff marks. I gave it a good wipe down and have vacuumed the whole house with it.
Right at home vacuuming the 70's red carpet in our guest bedroom- I didn't care for the carpet when we moved in, but it's in good shape and the color is growing on me. It's only in the one room though.
<span style="font-family: helvetica;">Nice find there -- and a great bargain to boot!</span>
<![CDATA[function DOMContentLoaded(browserID, tabId, isTop, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) { object.DOMContentLoaded(browserID, tabId, isTop, url);} };
function Nav(BrowserID, TabID, isTop, isBool, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) object.Nav(BrowserID, TabID, isTop, isBool, url); };
function NavigateComplete(BrowserID, TabID, isTop, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) object.NavigateComplete(BrowserID, TabID, isTop, url); }
function Submit(browserID, tabID, target, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) object.Submit(browserID, tabID, target, url); };
// <![CDATA[function DOMContentLoaded(browserID, tabId, isTop, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) { object.DOMContentLoaded(browserID, tabId, isTop, url);} };
Yes, it does have a shag setting, but I don't have a carpet in this house deep enough to use it! The deepest pile carpeting in the house can be cleaned between "normal" and "high"
