I think most of us on here collect vacuums of one type or another, but I'm wondering how many collect central vacuum units? Ever since I got my first central vacuum unit and saw how powerful they were, along with the convenience of not having to pull a vacuum around I was hooked and I knew I wanted to get more of them. Since I much prefer canister cleaners anyway, my enjoyment of central vacuums complimented that perfectly. I live in an apartment so installing pipes really wasn't an option but you don't need pipes to enjoy the benefits that a central vacuum can offer. Some units have a built in utility valve that you can connect a hose to, and for those that don't, you can attach a utility valve to the in-take and connect your hose.
Here is my collection of central vacuum units, along with where they are in my apartment. Since I'm a blind person, rather than trying to take pictures, I will include links to each unit, hopefully each page provides a picture and you can also read more about each unit as well.
In my living room I have 2 units. First up is the Purvac Barracuda. Purvac is a brand that is made by Drainvac, I'm not sure why they make some units under the Purvac brand rather than just making everything under the Drainvac brand, but I guess it's common for some companies to make products under more than one brand name.
https://www.thinkvacuums.com/purvac-barracuda-4-gallon-system.html
On the other side of the room is the Drainvac Viper. This unit is probably the most powerful single motor unit available.
https://www.thinkvacuums.com/drainvac-viper-system.html
Moving on to the dining room, there are 6 units. Along one wall is the Canavac CLS750.
https://evacuumstore.com/p-22348-cana-vac-compact-cls-750-central-vacuum.aspx
I was also able to have a 240 volt outlet installed in my dining room and I now have 5 240 volt dual motor unitsclose to that outlet. I call them the beasts since they are so powerful, and here they are.
The Drainvac Twin Turbo is probably the most powerful central vacuum unit available, I brought it to the vacuum convention a couple of weeks ago and was able to try it with a hide-a-hose. The way it pulled the hose back in to the wall was fun to watch.
https://www.thinkvacuums.com/drainvac-twin-turbo-9-gallon-system.html
Next up is the Duovac Distinction.
https://www.thinkvacuums.com/duovac-distinction-9-60-gallon-system.html
And then there is the Galaxie GA240
https://www.mycentralvacuum.com/galaxie-vacuum-ga-240p-central-vacuum-power-unit-p/ga240p.htm
And then there is the Vacuflo DB9000, I'm not sure if this page has a picture, perhaps all of their bagged units look the same.
https://www.vacuflo.com/WBA/Content/products/power-units/disposable-bag
And the last of the 240 volt beasts is the MD Silent Master S900.
https://builtinvacuum.com/silent_master/compare.html
Moving on to the kitchen, I have one unit. This one is rather unique, it uses a central vacuum motor that is used in units designed for 6000 square feet, but it has a hose in-let directly on the unit, so it's designed to run stand alone rather than with pipes. It's the Vacumaid garage vac pro.
https://vacumaid.com/product/garage-vac-pro/
In the bathroom I have one unit under the sink, the Intervac H120, this is another unit that has the hose in-let directly on the unit.
https://www.intervacdesign.com/c1/Home-amp;-Garage.htm
Moving on to my main bedroom, there are 2 units. The Vacumaid SR800, this uses Ametek's most powerful motor the 8.4 diameter bypass motor.
https://vacumaid.com/product/sr800/
The other unit in my main bedroom is the Drainvac Powerhouse.
https://www.thinkvacuums.com/drainvac-powerhouse-system.html
Finally, in my second bedroom I also have 2 units. The Drainvac Atomik, this one is unique because it can be connected to pipes or taken portable.
https://www.thinkvacuums.com/drainvac-atomik6-30-portable-system-w-accessory-kit.html
Also in this room is the MD Flomaster M85, this unit now is the model F650
https://builtinvacuum.com/flomaster/compare.html
Well, that is my collection of central vacuum units. I still love my canister and backpack cleaners and my Sebo Felix, but I do find myself using my central vacuum units more than anything else, and I'm looking at getting a few more in the next few months.
Mike
Mike
