Model 89 mint mint
Took the motor out of the lux 89 and gave it a clean and bloew out the dust whit the trsitar cxl in blower mode crevic tool on the hose whata cloud of dust came out !!!
My Electrolux mode lZB 89 runs quieter smooter more power suction air flow sooo glad she is working much better .
but im leaving the Pn as is for now think it came out good yes duct tape .... on the sealth helps wand stay in .Now this LUX 89 has spare parts and she works good whit a matching set. At last no issues ok not perfect but ok note my vacs are NOT SHOWROOM there use to clean ty.
To stop the bag squeak
To stop bag squeak do not remove the tab off the bag, that keeps it from making that noise.
You painted the sheath? It looked like it matched the hose and was fine. I noticed the tape on the sheath is it damaged? If the lower wand won’t stay in that’s because the clip to hold the together is bent and it can be adjusted so this doesn’t happen and you don’t have to tape it. I don’t know about you but I’m not a big fan of having things taped together, I prefer to repair the issue making things work properly.
I haven’t had great luck with painting stuff, tend to chip off and then look bad so I learned my lesson the hard way on that . At least most of what you have painted can be replaced if they end up a mess.
Hope it works out for you though.
Jon
I think it’s 60’s
Not sure on the Canadian models but this is very similar to the US model G which was out from 1961-1968. I know these 89’s had a long long run and were continued longer after the G was replaced by the 1205. Your tools though date back to the XXX style but it seems Electrolux of Canada didn’t change to the flip over rug and floor tool in 1953 That was introduced on the US model E so those 40s style rug and floor tools were continued in the older style on the 89.
Jon
