@georgect,
I hear where you are coming from but everyone's cleaning requirement is different. To some the short cord of Miele is a drawback, to others it is not a deciding factor. Hoses... well if you didn't get the capricorn or the uniq then the hose is actually longer on the other electronic hoses. I measure this for myself in the Miele showroom recently.
Weight is an issue for some... I have the Miele S8 Marin (cross shoped with Sebo D4, Aeurs, TriStar, Filter Queen, etc) and the weights are as follows:
S8 - Marin Canister (with empty new bag in it.. no hose attached) -- 11.8 lbs
S8 -- electric hose (no head attached) -- 2.6 lbs
Miele Electronic wand (SET 220) -- 1.8 lbs
Miele SBB-300 floor tool -- .6 lbs
Miele SEB236 power head -- 6.2 lbs
Put together for floor cleaning with SBB300 on scale -- 16.9 lbs
Put together for carpet cleaning with SEB236 on scale -- 22.6 lbs
Cord length (measured from bottom of prongs to entry into the cansister.) -- 21.3 ft
Miele S8 electronic hose measure with tape measure -- 7 ft.
Miele SET 220 electronic wand fully extended is -- 38.4 inches
