@chicagomike - Looking at pic #1, the lower joint on the upper-most track looks a little crusty. It's hard to tell a cracked joint sometimes, even in person, under a magnifying glass. It could also just be a ring of flux crust. If you have a soldering iron and some flux, apply a touch of flux to it, then reflow the solder. Might be the only problem.
I'm trying to figure out what the other component is, nothing comes up for either number. I'll bet that's an internal number, and the real number is likely under that heatsink-looking thing on it (the one with the blue number sticker on it). The board has large tracks for it, with good separation between the two terminals. If I had to venture a guess, I'd say it's a fuse of some kind. It's between one side of the triac/thyristor's connection. Perhaps a thermal fuse, but that's an odd package, and it's in a weird place and wrapped what almost looks like a heatsink with a thermally conductive sheet thingy in between. Either which way, it looks like it should be continuous. Get out the multimeter and check resistance across it, then compare with the known-good one. I'll bet the known-good one is less than 1 ohm.
Continuation of the bickering: I'm usually quick on the draw to tell people they're just having a misunderstanding. But I was insulted, then he apologized, and proceeded to insult me more. Now he's taking pot shots at me for being a brony. lol getting desperate, are we? When you can't hold up your end of an argument, turn to insults? Couldn't even muster a good brony insult, I'm disappointed. Oh, and he also threw vaclab under the bus as well, just for good measure, and he wasn't even involved in our little 'adult conversation.' If that doesn't show you what kind of person vacuumdevil is, idk what will.
