Hi all
Following on from the recent Miele discussions, my red cylinder/canister model arrived yesterday (spares/repairs for £18 on ebay UK). The initial fault was that it would not run. I tracked this down to a bad solder connection on the thermal cut-out component on the motor PCB. Having resoldered this, it works...success!
However, for a Miele it is very noisy. The cleaner has very few scratches/marks on it suggesting quite an easy life, but there was some plaster dust on the inside of the bag compartment and clogging the prefilter. I know; one of the best ways to kill a vacuum! The suction is still excellent.
Does anyone have any suggestions for remedying this noise? This model was a BOL a few years back, but I believe it has the same motor fitted as the S4/S5 models from that time. Is it possible to service the motor or check the bearings at all on these? It is hard to describe, once shut off it seems to have a low 'rumble' sound for a few seconds as the motor winds down.
Additionally, the telescopic extension tube has an annoying habit of collapsing. The ratchet to adjust the tube height works and locks in an upwards direction (e.g. pulling floorhead back), but put any pressure on the tube pushing forwards and it slides down. Would this be potentially repairable if I remove the plastic button and reassemble?
So far it is not seeming such a bargain! Any help would be much appreciated!
cheers
cheers
