Metal or Plastic Fan?
Sentria airflow
Blackheart,
I believe I have seen videos on youtube of a Kirby Sentria pulling a 10 on the Baird airflow meter. The Sentria which has an Amodel fan is touted as having the most airflow (115 CFM) of any previous Kirby model. The G3 has only 107.5 CFM. Have you tested a Sentria with your Baird meter?
well
If you test a kirby at the fan case they will pull a 10 my G6 will pull a 10 and i believe the G3 would too.
I did not test them at the fan case though. All three were tested at the end of the same Heritage II hose (the machine had needed to be swapped out to use with the G6)
To answer your question i have not measured a sentria
