Thanks <a name="start_16153.172517">Gareth, I think I might invest in a tool that reads RPM...I can use it on many other small electric motors as well. What sort of tool do you use for this task? How can I find out what the factory RPM range is supposed to be for the 1205 and the G motor? That would at least tell me if the motor is putting out sufficient RPM's and if so, I can leap-frog to the fan impeller stages and fan box seal....although I redid the seal with no significant result.
</a>
<a name="start_16153.172517">Kevin </a>
</a>
