danemodsandy
- Joined
- Mar 27, 2007
- Messages
- 1,701
Hello:
I am PUZZLED. I just found a PN-1 in a thrift (along with a 1205), and it's very noisy, due to a badly worn brushroll bearing. I know new bearings are readily available, but I cannot for the life of me see how to get the old bearing off and the new one on. The problem is on the gear wheel end of the brushroll. While the gear wheel and its shaft pull out of the end of the brushroll easily, the bearing and a little sleeve are held onto the shaft by a little pair of "ears"; there seems to be no way to remove the bearing or to put another one on. What am I overlooking here? I'm attaching a little sketch to show what I mean. This bearing must be replaced; its hole that the shaft passes through is worn to a very wobbly oval shape, instead of round like it should be.
