Brian:
Here is a pic of my complete set of TriStar attachments, plus a couple of "extra" things that I put with it for the sake of convenience. None of it is aftermarket or bojack stuff. Shown are:
- A genuine TriStar hose
- The power nozzle with its wands
- A genuine TriStar metal floor tool
- A genuine TriStar metal rug tool
- A genuine TriStar tool caddy (clipped to a second set of wands; it's holding the small tools onto the wand)
- A genuine TriStar crevice tool (clear/glitter)
- A genuine TriStar upholstery tool complete with grille (clear/glitter)
- A genuine TriStar dusting brush (clear/glitter)
- An instruction manual for the CXL/DXL/EX-20 TriStar machines.
In addition, these bits are extras:
- A second set of wands, so that I don't have to remove the wands from the power nozzle when I want to use the floor tool or the rug tool
- A "rug shoe", which is an attachment in clear/glitter that clips onto the bottom of the floor tool to convert it to a rug tool. I have it only for the sake of completeness; the rug shoe attachment never did work very well, in my opinion. It's hard to put on without bending the bristles of the floor tool, and it has a tendency to drop off the floor tool when you're using it- most annoying.
So, now you can see everything your machine is supposed to have. I put all of this together from four major sources. First, some of it came with the machine, which I purchased from Nathan Thomas ("electrolux-dude") of this list. Second, some of it came from eBay. The hose and rug tool came from TotalVac, whose service I cannot recommend, I'm sorry to say. And the manual came from TriStar Canada, whose service I
can recommend. A link to TriStar Canada is below. They carry most every part for your machine, plus their Website has a complete parts manual that you can download in PDF format. The machine you have is probably an EX-20, based on the description you give. If its a CXL or a DXL, they're basically identical to the EX-20 except for colour, and the same parts manual applies.
Also, if you find a clear/glitter dusting brush, it's likely to have dead bristles, since these are pretty old by now. You can tell when bristles are dead by the fact that they break off and drop all over the place when you use the brush. The new brown dusting brush uses exactly the same bristle insert, so you can just buy a new dusting brush and use its bristle insert in the old clear/glitter dusting brush. This is what I did.
Again, hope this helps!
http://https//www.tristarvacuumscanada.com/
