centralsweeper63
Do you know how to remove and replace rivets?
Brushes have to be removed before the motor comes out, you can't remove the motor from the housing until the brushes come out first.I drilled the rivets out, and I have the bearings out, but I might have bent the fan side bearing holder while pressing it out with the puller, not sure how bad it is yet, also one of the brushes on the motor broke while I was tapping out the belt side bearing, I guess just from the tapping force. Not sure if I’ll proceed at this point.
Now you remove the rivets and replace them with screws and nuts with a wave washer and blue locktite.I got the cover off, but it still looks like I would have to remove the rivets in order to replace the bearings. Any other ideas?
There are several videos showing how to replace brushes in the brush holder. It requires a little soldering but not too bad.I drilled the rivets out, and I have the bearings out, but I might have bent the fan side bearing holder while pressing it out with the puller, not sure how bad it is yet, also one of the brushes on the motor broke while I was tapping out the belt side bearing, I guess just from the tapping force. Not sure if I’ll proceed at this point.
