Looking for motor for Panasonic MC-663 upright
b850
Indiana
I'm looking for a replacement motor for our Panasonic MC-663 Jet-Flo. The motor says Matsushita 2V-531N on it. It needs new bearings I think, and the fan housing is riveted on and will be a real pain to disassemble. If anyone has one in good shape, let me know.
    3 MB
    2.6 MB
    2.8 MB
Finding an original replacement will be tough. You would have to show me the fan opening but if those motors are made like their same year canister motors they are quite repairable. The fan should be retained by a hex nut and flat washer. I would like to see if there is a lip on the fan housing you can get the blade of a screwdriver on so you can tap tap the fan housing off. The images make the motor appear to be single stage. is that the case? You will need a press to get the bearings out, especially the upper one can be stubborn but they are repairable. I had some early 1980s motors rebuilt by a local vac shop and laughed when searching for the bearings. They were a popular front wheel bearing for quads so there was a huge selection from every manufacturer. I went with bearings from the Japanese company Nachi. They are high quality and probably what Panasonic used originally.
Ok thanks cheesewonton. I’ll try to get it apart and replace the bearings. I already replaced the roller bar bearings, they were Nachi 262Z, found exact replacements online.
I've recently managed to get my hands on one of these (in NZ so the 230v version). Mine has a pretty rough sounding motor too, I haven't had a chance to pull it apart yet but I'd been hoping simply refreshing the lubrication on the bearings would see mine right for now. After I've cleaned it up I'm not likely to use it much (getting spare parts for older machines in NZ can be a pain ,and international shipping can be cost prohibitive), so unlike me it's probably just gonna sit around & look pretty! lol
Motors rarely ever go bad unless it fails so catastrophically that the windings short out. It's 96.9% of the time dry bearings or worn bearings.
This yummy blue goo is what you want to feed your vacuum cleaner motor. It's way overkill for a small motor but it ensures it lasts permanently in such a small application (these are made for industrial machinery motors that fill half a room) and it makes a huge difference.
That is ok if you have shield bearings and can remove the metal shields. If you have sealed bearings, many do, then you cannot lubricate them. You remove and replace them.
Yeah, repackable bearings are terrific!
There is good and bad. Shield bearings are not dust tight. Bearings with lip seals are. And while you can't repack a sealed bearing, once you have the bearing out I kind of don't see the point of repacking a bearing that is worn. Bearings of the size used in most vacuum motors are pretty inexpensive. Even good ones. Once I have a bearing out on the bench I see little value reusing it. I just toss them and replace them with a good quality ( Nachi, SKF ) sealed bearing.
So I confirmed the fan “cover” is not simply pressed on. Rather, it is riveted to the fan motor cover, from what I can see. So it appears the rivets would have to be drilled out. I thought I saw another thread about using low profile screws or something. Let me know if you guys have done this. IMG_4358.jpeg
So I confirmed the fan “cover” is not simply pressed on. Rather, it is riveted to the fan motor cover, from what I can see. So it appears the rivets would have to be drilled out. I thought I saw another thread about using low profile screws or something. Let me know if you guys have done this. View attachment 171319
Are you sure those rivets are not just holding the motor base to the outer metal housing? The fan housing should be a press fit, not riveted.
No. The rivets you see hold the metal field housing to the motor base. The fan housing is not riveted on. I have not had that particular motor apart but have had similar Panasonic vacuum motors from that era apart.
I’m pretty sure they are holding the fan shroud on. Saw this thread also:
https://vacuumland.org/threads/question-about-the-panasonic-jet-flo.11091/
Well then I have no clue how to get it apart.
Show me a clear image of the fan housing from the side so I can see how it fits into the motor base. Most of the time you either get a chisel or very thin flat blade screw driver in between the fan housing and base and patiently tap tap tap around that seam until you work the fan housing off, or you give it some hits with a rubber mallet or nylon hammer to dislodge it. They should be an interference fit to the motor base.
I see now that there is a tiny seam where the fan cover meets the motor cover. I just couldn’t see it before. I’ll work on getting it apart and report back. IMG_4371.jpeg
Just go slow and carefully so you don't bend the metal. I would try a sturdy chisel and a mallet and just try and work it in the crack and hopefully it starts sliding apart. It's always a challenge making something come apart that was not designed to come apart.
That lip is so large I would be tempted to cut a couple of notches in it so you could get a better angle with a screwdriver on that overlapping edge. Without that lip it would be really easy to knock the outer fan cover off.
I wouldn't cut anything out, out of risk of compromising the motor's performance or suction.
I got the cover off, but it still looks like I would have to remove the rivets in order to replace the bearings. Any other ideas?
    2.8 MB
    2.9 MB
